For IPv4 and IPv6 address families:
show bgp routes {address-family [ipv4-unicast | ipv4-multicast |ipv6-unicast | ipv6-multicast | ipv4-vxlan | {l2vpn-evpn [inclusive-multicast | mac-ip | auto-discovery | esi | ip-prefix]}]} {detail} [ipv4-vxlan | all | as-path path-expression | community [no-advertise | no-export | no-export-subconfed | number community_number | autonomous-system-idbgp-community] | network [any/netMaskLen | networkPrefixFilter] {exact}] {vr vr_name}For the VPNv4 address family:
show bgp routes address-family vpnv4 {detail} [all | as-path path-expression | community [no-advertise | no-export | no-export-subconfed | number community-number |autonomous-system-idbgp-community] |rd rd network [any/netMaskLen |networkPrefixFilter] {exact}] {vr vr_name}Displays the BGP route information base (RIB).
ipv4-unicast |
Specifies the IPv4 unicast address family. |
ipv4-multicast |
Specifies an IPv4 multicast address family. |
ipv6-unicast |
Specifies the IPv6 unicast address family. |
ipv6-multicast |
Specifies an IPv6 multicast address family. |
| ipv4-vxlan | Specifies an IPv4 VXLAN address family. |
| l2vpn-evpn | Specifies an L2VPN EVPN address family. |
| inclusive-multicast | Displays EVPN inclusive-multicast (type 3) routes |
| mac-ip | Displays EVPN MAC/IP (type 2) routes. |
| auto-discovery | Displays EVPN auto-discovery (type 1) routes. |
| esi | Displays EVPN Ethernet segment (type 4) routes. |
| ip-prefix | Displays EVPN ip-prefix (type 5) routes. |
vpnv4 |
Specifies the VPNv4 address family for Layer 3 VPN support. |
all |
Specifies all routes. |
path-expression |
Displays routes that match the specified AA path expression. |
no-advertise |
Specifies the no-advertise community attribute. |
no-export |
Specifies the no-export community attribute. |
Specifies the no-export-subconfed community attribute. |
| community_number |
Specifies a community number. |
| autonomous-system-id |
Specifies an autonomous system ID (0-65535). |
| bgp-community |
Specifies the BGP community number. |
| rd |
Specifies the Route Distinquisher (RD) value for the Layer 3 VPN routes for which you want to clear flap statistics. |
| any |
Specifies all routes with a given or larger mask length. |
| netMaskLen |
Specifies a IPv4 or IPv6 subnet mask length (number of bits). |
| networkPrefixFilter |
Specifies an IPv4 or IPv6 address and netmask. |
| exact |
Specifies an exact match with the IP address and subnet mask. |
| vr | Specifies viewing routes associated with a specified virtual router. |
| vr_name | Specifes the VR name. If not specified, the VR of current command context is used. |
If no address family is specified, IPv4 unicast is the default.
The option network any / netMaskLen displays all BGP routes whose mask length is equal to or greater than maskLength, irrespective of their network address.
The option network any / netMaskLen exact displays all BGP routes whose mask length is exactly equal to maskLength, irrespective of their network address.
To display Layer 3 VPN information, you must enter this command in the context of on the MPLS-enabled VR; it is not supported for BGP neighbors on the CE (VRF) side of the PE router.
You can only execute the show for vpnv4 address family in a VR context. If you execute this command in a VRF context, the “Cannot execute command in VRF context” error is displayed.
This command applies to the current VR or VRF context.
If you do not specify an address family, this command applies to the IPv4 unicast address family. To apply this command to an address family other than the IPv4 unicast address family, you must specify the address family.
The following command displays detailed information about all BGP routes:
* Switch.5 # show bgp routes all
Received Routes:
Destination LPref Weight MED Peer Next-Hop AS-Path
*>? 1.1.1.1/32 100 0 11.0.0.1 11.0.0.1 100
* ? 11.0.0.0/24 100 0 11.0.0.1 11.0.0.1 100
*>? 101.0.0.0/24 100 0 11.0.0.1 11.0.0.1 100
u ? 103.0.0.0/24 100 0 11.0.0.1 11.0.0.1 100
Flags: (*) Preferred BGP route, (>) Active, (d) Suppressed, (h) History
(s) Stale, (m) Multipath, (u) Unfeasible
Origin: (?) Incomplete, (e) EGP, (i) IGP
BGP Route Statistics
Total Rxed Routes : 4
Feasible Routes : 3
Active Routes : 2
Rejected Routes : 0
Unfeasible Routes : 1
Route Statistics on Session Type
Routes from Int Peer: 4
Routes from Ext Peer: 0
The following example displays a detailed show output:
Route: 11.0.0.0/24, Peer 11.0.0.1, Unfeasible
Origin Incomplete, Next-Hop 11.0.0.1, LPref 100, MED 0
Weight 0, RR Orig ID 0.0.0.0
AS-Path: 100
DampInfo: Penalty 0 Flapped 0 times in 00:10:47
Total Rxed Routes : 1
Feasible Routes : 0
Active Routes : 0
Rejected Routes : 5
Routes from Int Peer : 5
Routes from Ext Peer : 0
The following command displays BGP information for the IPv6 address family:
Switch.21 # show bgp routes address-family ipv6-unicast all
Received Routes:
*>? 2001::/64 100 0 120
3000::1 3001::1 100, 200
Origin: (?)
Feasible Routes : 1
Active Routes : 1
Rejected Routes : 0
Unfeasible Routes : 0
Routes from Int Peer: 1
The following example displays detailed show output for the IPv6 address family:
switch.21 # show bgp routes address-family ipv6-unicast all
Route: 2001::/64, Peer 3000::1,
Unfeasible, Origin Incomplete,
Next-Hop 3001::1,
LPref 100, MED 0,
AS-Path: 100
Route: 2002::/64, Peer 3000::1,
Active, Origin Incomplete,
Next-Hop 3001::1,
LPref 100, MED 0,
AS-Path: 100
Total Rxed Routes : 2
Feasible Routes : 1
Active Routes : 1
Rejected Routes : 0
Routes from Int Peer: 2
The following examples display detailed show output for the IPv4 address family:
switch.21 # show bgp routes address-family vpnv4 all
Received Routes:
*>? 100:1:10.0.0.0/8 100 0 120
11.0.0.2 11.0.0.2
100, 200
Feasible Routes : 1
Active Routes : 1
Rejected Routes : 0
Route: 100:1:10.0.0.0/8, Peer 11.0.0.2,
Next-Hop 11.0.0.2,
LPref 100, MED 0,
AS-Path: 100
Feasible Routes : 0
Active Routes : 0
Rejected Routes : 0
The following example displays detailed show output for the IPv4 VXLAN address family:
# show bgp routes ipv4-vxlan all
Routes:
LTEP VNI Peer Next-Hop LPref Weight MED AS-Path
* i 1.0.0.15/32 777 192.168.68.1 192.168.68.1 100 1 0 15
The following example displays L2VPN EVPN MAC/IP routes:
# show bgp routes l2vpn-evpn mac-ip all
EVPN MAC/IP Routes:
MAC IP VNI Peer Next-Hop AS-Path
*>? RD: 65535:4294967295 ESI: 00:01:02:03:04:05:06:07:08:09
00:04:96:98:87:62 192.168.110.109 16777215 192.168.120.119 192.168.120.119 50 40 30 20 10
*>i RD: 192.168.101.100:65535 ESI: 00:00:00:00:00:00:00:00:00:00
00:04:96:98:87:63 0.0.0.0 16777215 192.168.0.3 192.168.0.3 50
*>i RD: 4294967295:65535 ESI: 00:01:02:03:04:05:06:07:08:09
00:04:96:98:87:64 192.168.110.110 777 192.168.120.119 192.168.120.119 50 40 30 20 10
The following example displays L2VPN EVPN inclusive multicast routes:
# show bgp routes l2vpn-evpn inclusive-multicast all
EVPN Inclusive Multicast Routes:
Originating IP Tunnel ID VNI Peer Next-Hop AS-Path
*>? RD: 65535:4294967295 Ethernet Tag: 0 Tunnel Type: 6 (Ingress Replication)
192.168.110.109 192.168.110.109 16777215 192.168.120.119 192.168.120.119 50 40 30 20 10
# show bgp routes l2vpn-evpn ip-prefix all
Routes:
EVPN IP-Prefix Routes:
IP Prefix/Length VNI Peer Next-Hop AS-Path
? RD: 1.0.0.25:48 ESI: 00:00:00:00:00:00:00:00:00:00
125.126.127.128/32 777 192.168.99.2 1.0.0.25 38 25
? RD: 1.0.0.25:49 ESI: 00:00:00:00:00:00:00:00:00:00
1.0.0.0/8 778 192.168.99.2 1.0.0.25 38 25
BGP Route Statistics EVPN route type 5
Feasible Routes : 2
Active Routes : 0
Rejected Routes : 0
Routes from Int Peer: 0
Routes from Ext Peer: 2
The any / netMaskLen options were added in ExtremeXOS 11.0.
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
Support for IPv4 VXLAN was added in ExtremeXOS 22.3.
Support for L2VPN EVPN was added in ExtremeXOS 30.2.
Support for user-specified VRs was added in ExtremeXOS 30.3.
Support for EVPN auto-discovery and EVPN Ethernet Segment routes was added in ExtremeXOS 30.4.
Support for Type 5 routes (ip-prefix) was added in ExtremeXOS 30.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
